General Whining noise when in high revs
philmoore
Hi, my fiat punto 55s has started to whine when its driving in almost all gears when i hit 3000 revs a high pitched whine will sound if i stay below that its fine, when the car is stationary i can rev the car and its fine, it only does it when the car is moving the noise sounds when i apply pressure to the accelerator in high revs, please help
Thanks in advance
is it expensive and can it be done by myself ?
Thanks for your help
I think you'll need the whole new tensioner if it's that. The tensioner is all one part @ £20
If you change the tensioner, change the belt too... same sort of wedge.
Ralf S.
Ralf S.
so its just the tensioner bearing and i may as well change the belt while im there.?
you get belt and tensioner as 1 kit about £0 from a motor factors, ask them what make kits they do, try and get a gates one
hmm, wondering if this is the same problem with my MK2 Sporting.
When in 6th gear, going around 40-60mph, the car makes a slight whining sound. Thought it was quite cool as it sounds a bit like a aeroplane :), but could this be a potential problem??
Ok pissed now,
i just dont know what this squealing high pitched noise can be so far i have done the following:
Drivebelt change
Checked alternator
Timingbelt + tensioner kit
Waterpump
any ideas as to what this could be the manual points to it being a blow gasket of some sort please help :confused:
Sounds like potentially a clutch/geerbox problem seing as it onlyt does it when your mooving. Have you checked your geerbox oil?
Good luck,
Alan
Ah it does actually do it when its stationary in neutral so that would cancel that out as the clutch is not engaged.
Does the catalytic converter make this noise when it is fooked as i have recently had the front downpipe changed, the noise and performance loss was after that change.
Bloody garages
Is the fan belt in good nick (and tensioned)? Dunno if you have power steering.. but check the fluid level and belt tension, if you do.
Ralf S.
Fan belt is brand new and tight all belts tensioned properly.
Thanks. problem still persists.
My punto mk2 1.2 mia does exactly the same, did you manage to sort this problem in the end? cheers
Mine does it but I'm convinced it's a slight air leak where the air filter bolts onto the side of the engine.
