Styling which rear lights......
which ones would look better?
  • chrome
    Votes: 0 0.0%
  • black
    Votes: 1 5.9%
  • none they all chav, just tint your own
    Votes: 16 94.1%
  • Total voters
    17
:D google wheel pcd and look in the listings you will then see what the pcd for a punto is , and from there compare against other cars to see what will fit but be carefull on the bore size as this is the size needed to cover the hub nut so going bigger aint a problem cause you can get some spiggot rings but dont go smaller than your bore ,,,,, hope this helps ,,,,(y)
Punto I94 to 004x9835 to 4258.1
ok got this ^. it means naff all to me lmao hopefully people put these in their listings tho! spiggot rings? bore? im clueless sorry :ROFLMAO: ill figure it out im sure...
ok people dont put that in their listings..... seen a nice pair i sort of like tho! 120336168484 ebay. wouldnt go to liverpool n pick them up tho!
well im a complete car novice, female, and im trying to learn about these things so i can do my car up a bit! :ROFLMAO:
i always thought wheels were wheels. as long as the inch size and studs were the same, i thought they would fit. started looking and got met with loads and loads of different types and havnt a clue what im looking at!
ANY OF THESE MODELS WILL FIT (y)
Fiat Model Year PCD Offset Bore Barchetta 95> 4x98 35 to 42 58.1 Bravo & Brava 96 to 01 4x98 35 to 42 58.1 Coupe 16V 95 to 01 4x98 35 to 42 58.1 Doblo 01> 4x98 35 to 42 58.1 Florino 95 to 00 4x98 35 to 42 58.1 Idea 03> 4x98 35 to 42 58.1 Marea 96> 4x98 35 to 42 58.1 Multipla 99> 4x98 25 to 38 58..1 Panda 03> 4x98 30 to 38 58.1 Punto I 94 to 00 4x98 35 to 42 58.1 Punto II 94 to 00 4x98 35 to 42 58.1 Stilo 01> 4x98 35 to 42 58.1 Tipo & Tempra 88 to 95 4x98 35 to 42 58.1 Uno 85 to 95 4x98 35 to 42 58.1 Uno Turbo 85 to 95 4x98 35 to 42 58.1
4x100 wheels will fit aswell with the use of wobbly bolts. centre bore size is 58.1mm so that size or any bigger will be fine because spigots can be used. You can fit up to 17s on a punto but best bet is to go for a 16 or 15 inch wheel. Offset needs to be around 35 but if it is slightly higher( 36+) then a spacer can be used to reduce it or it can be slightly lower aswell as this will just mean the wheel sits futher out in the arch.
