Technical where the crank sensor at fiat coupe 20v
php3
where the throttle potentiometer sensor at fiat coupe 20v
hello guys
where can i see the throttle potentiometer sensor
my car is : Fiat coupe 20v turbo limited edition 1998y
when i make scan this error
Anomaly on the throttle position signal, signal absent or inconsistent. Check the following:
- Ignition ON, sensor supply between pin 1 (+ 5 V,pin 12 ECU) and pin 2 (-) of the sensor connector
- Signal emitted from the sensor, proportional to the throttle position, on pin 3 of the sensor connector, the plug connected and ignition switched ON
- Continuity and insulation of the signal conductor, between pin 3 of the sensor connector and pin 53 of the ECU wires bundle connector
The reason for this fault is Unknown / Short circuit
The current status of the fault is Intermittent / Present
The error counter value is 64
Re: where the throttle potentiometer sensor at fiat coupe 20v
Throttle sensor is located close to the throttle housing. You probably have a bad connection at the main multi plug. Follow the wiring. Undo. Probably rusty. You will need to do a continuity test of the wires.
