Technical Where can i buy these parts, urgently
Call the local bearing/engineering stockist. Most of them are standard off the shelf bearing seals. You probably will have to remove them to compare. Measure up before you call and see if there are any numbers visible like xxx/yyy/zz. Your local factor most likely does not supply but will probably know who does.
If the gearbox input shaft seal has failed you will also need a new bearing. The bearing fails takes out the seal and oils up the clutch. When doing the clutch, the bearing and seal should always be changed if there is the slightest doubt the bearing's condition. They are standard size parts from a bearing factors. Use tape on the shaft splines to protect the seal lip.
Crank seals are more reliable but might as well change them while the gearbox is out. See the bearing repair in the Punto Guide by @MrWild.
