- Joined
- Aug 23, 2007
- Messages
- 551
- Points
- 93
Please bear with me, i'm new here and i did actually use the search
What is the standard ET for a seicento and how big a spacer can i use? If I want to widen the car's wheelbase a little bit to improve handling, are spacers the way to go at all, or do you buy "wider" rims? I've read that one should go for hubcentric only to avoid wheel wobble, is ebay a good source? They do look a bit expensive, maybe it would be cheaper to find someone with a CNC to make them for me? If so, is there a spacer diagram somewhere, so i can tell the workshop what i need made? (i've googled for it, but not very successfully) What else will i need (nuts&bolts, anything lenghtened)?
Sorry for any spelling mistakes, english isn't my native language, all i share with you guys is the cento
Thanks in advance for any input! :worship:
P.S. I've read that sei abarth comes equipped with 10mm spacers in the front, is there any chance to find this on a scrapyard? Is it even compatible with the standard sei, and could it be used on the rear wheels too?
