What is the difference between an IAW 59F M1 and a M7 ecu
I swapped them over on my car and it seems to still run ok
Jim
Jim
Only cars with ME1-7 Ecus are Euro 3 engines, ie MPI.jims car mpi?
Do you really mean "ME1-7" or do you mean "M1-7" as in IAW 59F.M1 to IAW 59F.M7?Only cars with ME1-7 Ecus are Euro 3 engines, ie MPI.
Early Seicento MPI cars, S, SX and Van have the ME7.
Some thing like 2002 on some started having the IAW 4AF.M1 which I think are the Euro 4 ones in the early stage?
The code reader is coded to the ECU and stores/reads the codes in the keys to allow the ECU to run.
If you get another ECU, you need the code reader and at least one key to make things work. Then you have to mess around with programing new keys to the same code as the donor key.
Contact these....
http://www.ecutesting.com/
