Hmm definitely not the first thing that comes up if search for Enyaq and bricked at all
You definitely can't get similar lists by replacing Enyaq, with ID3..4, 5 or buzz either.
But anyway my point in this was mainly chances of your Golf bricking due to a failed OTA...zero. Chances of new car that's not built in the same way bricking due to a failed update. Well that's more than zero which is infinitely worse as a percentage I'm sure you'll agree.
It's almost like they redid the full electrical system at some point round about the mk8 Golf/Id when all the haptics started coming in. A generational shift if you will in the philosophy of the company.
I think you’re just grasping at straws here. Firstly if you read the posts in almost every case it’s the update failing that has caused the issue.
They are specifically electric cars the Enyaq 80 is the reoccurring theme, and I can put literally any car brand or model into Google with the term “bricked” and find some sort of result.
Now I guess the point you are trying to make is that my golf doesn’t do over the air updates, and you’d be right, but it still has updates just done with an SD card instead. Will that cause the car to completely go tits up? Probably not but then it’s not an electric car and I did make that point above. Electric cars are far more electronically complex as they have multiple power sources complex computers for controlling the electric drive train, it’s not just a variac and a battery like an old milk float.
My point is and remains that there is unlikely to be a massive difference in the parts and processes used to build something like the Skoda Scala, than my 10 year old golf, because vw doesn’t reinvent things (usually and not counting the iD cars) they evolve things over time.
I’ll refer you to my previous statement where I pointed out the Scala uses the same platform as the t-roc which was made into a cabriolet and vw repurposed the same roof for the t-roc cabriolet as was used on the golf cabriolet.
What you’re doing in this instance is called a straw man argument, you’re changing the focus of the argument to something else you can attack, but you’re going away from the actual point of the conversation to do that.
I don’t suppose that the skoda enyaq 80 a rear wheel drive electric cars, had a huge amount in common with a skoda Scala and definitely not a golf designed 15 years ago.
Just to put in context what I am saying here is the interior of a Scala and a Golf cabriolet do you really think that the technology behind both cars is really all that different. The two models show are only 3 years apart.
