Bit of an odd question, I'll explain.
My 2014 TA 4x4 came with no jack etc but did have a spacesaver and a towing eye. The spacesaver I realised was the wrong size being a 14" while the 4x4s if fitted with a space saver should have a 15".
I've rectified that with a new jack, wheel brace and space saver. As I expected the jack suitable for the 4x4 won't fit in the well of the space saver so has to live in a bag in the boot. Fine
However, on pulling things apart to get it all fitted I noticed that under the carpet in my car there was a piece of plywood cut to fit neatly that gives the boot a solid floor. With the 15" wheel in place this doesn't fit as the wheel is a tiny, tiny bit proud of the floor. The underside of the boot carpet has some padding so accommodates a slight discrepancy but you can feel the wheel under there if you press down.
Is that right? I can't see anything on the parts diagram that suggests I am missing a cover or similar.
- Model
- TA 4x4
- Year
- 2014
