Navin Talati
- Joined
- Oct 23, 2006
- Messages
- 106
- Points
- 97
What is the effect of a missing screw fitting clutch-kit to flywheel?
Actually in my Linea T-Jet, I had to change (replace) it's clutch kit and actuator (I.e. a single unit consisting clutch bearing and slave cylinder). On refitting every thing and remounting the gearbox as usual, it was found that the technician fitted only 8 screws and missed 1 while mounting and fixing clutch kit cover on the flywheel! To fit this 1 screw again the whole labour of removing the gearbox and refitting it is required which is very straineous and painstaking job again.
The car is running normal and seems no issue at present.
If I let go that 1 screw, then What is the effect of a missing screw fitting clutch-kit to flywheel?
Please guide me.
Navin Talati
Please guide me.
Navin Talati
