Technical Weird temp activity & no fan
Delux
England
Hi Fiatistas!
I picked up another Panda 4x4 today, a 1.2 8V to add to the Fiats in the household. Thankfully I noticed it needed coolant before driving it home but I did notice the temp gauge jumping up & down with an intermittent blinking engine check light.
When in in slow traffic I didn’t notice the fan come on,even with AC running. When I arrived home the temp gauge was doing a jig at idle but no fan going. Which is weird cos I know from our 1.2 500s that the fan usually comes on, so I’m a little perplexed.
The fan is not seized. Coolant was still stable (I did bleed it before heading home) so I don’t think it’s an air lock but it’s possible.
I’ve plugged it in to my Topdon Artdiag diagnostic tool and a can read all the modules and there are only two fault codes relating to the misfire (which I expected and will be sorting ) but nothing relating to anything else. I read the live feed for the coolant temp and it was jumping up & down but the light was then red on the temp gauge which it hadn’t been on the drive over.
I think I’ll start replacing some likely culprits like the temp sensor and try bleed the system again to be sure.
No mayo is present on the oil cap.
Any ideas and how can I activate the fan to see if it’s working?
Thanks!
Model
Panda 4X4 1.2
Year
2010
MES does this via the ECU I dare say you could unplg the fan and hot wire it direct to the battey to test the motor, Mes would help by giving a real temperature reading. Maybe the ballast resitor on the fan circuit is failing / failed.
Thanks for the response. I’ll look into MES. Is the Ballast resistor a replacement part?
Activate the fans using bidirectional software
Or
Thank you guys! I'll look into this and post my progress.
Are there wiring diagrams somewhere to download?
@koalar where did you access that function? I can't find that on my ArtiDiag 600 S.
UPDATE - that's because my model doesn't have bidirectional control.
Going to download the free version of MES now and use a spare KL (VagCom 409) USB interface that I have to see if the fan can be actuated.
Ok, some progress. I downloaded MES and used my KKL cable and got connected. Went to Actuations found Fan 1 and Fan 2 - tried them both and heard the relay/fusebox responding but no fans...
Unplugged the fan connector and inserted multimeter, had the wife Execute the fans one by one and got 12v at the plug.
So fan must be dead. Going to order a new one up.
Misfire is cylinder three P0303 - which one is that looking at the car from front?
Interestingly I tried to actuate the Water Temp light and that failed - although it does blink on startup. Why not do you think?
I also tried the Rev Counter test and that didn't work either (but it does work) but the AC clutch works in actuation.
Right
If you have power on pin 1 you only need to check continuity to gound on pin 2 to C045
Before calling a fan
No
Fans are computer controlled
Using information from
Coolant sensor
Aircon pressure sensor
One fan, one resistor module for the two speeds, two relays and two fuses
Cars without aircon generally only have one speed
There's at least half a dozen different slight verifications LPG, dualogic and so on
Thought you had already test voltage switching on and off at the fan, but it's not spinning,
I'd have put a test light on the two pin and activate it on and off, it would prove the power and earth is okay and the wires was able to carry to current, if the lights work and the fan doesn't, I'd be taking the fan off
I would test double test the fan off the car by applying voltage to it before ordering
I don't apply voltage to an unknown circuit, especially not current limited in the vehicle, there's a small chance if it faulty of causing a fire,
Update: applied 12v directly to the fan with ground to battery - fan worked.
Removed all the conduit to expose the wires and I traced the ground to the chassis rail, removed it and cleaned with sandpaper. That ground wire takes a nasty 90º turn that's left a good kink in the wire, so I may cut it out and ground to the cluster on the battery.
Reconnected the fan plug and started the car with AC on full. Fan came on after about a minute.
Good I thought. Better test it again. Waited a few minutes while I packed away tools & gubbins.
Started up a second time, waited about 5 minutes on idle with AC on full. No fan...
Going to try actuate it with MES after work.
Tried to actuate the fan with MES and nada. Then I tried again and as I heard the relay click I gave the fan a little nudge… it started to spin but like a wheel that needed oiling!
New fan ordered! Hopefully that will be that. Update to follow.
Update - fitted a new fan and actually used the car today after doing some other gubbins.
All seemed well until car lost power.
Fan working, coolant level good, heater pumping. So in my mind thermostat is working and coolant is circulating.
Car smelt like it was overheating…
Why power loss?
