General Weekend: Main headlights n deep beam headlamps turn on At The Same Time
s_prince
Hello
I have recently bought a FIAT MAREA WEEKEND 115 2000. Now I have a little problem with it.
The dipped beem headlamps don't turn on any more. But when I turn on the main beem headlamps, the dipped beem lamps also turn on.
I have cheecked the fuses and they are all ok.
Can any one figure out why the dipped beam lights donot turn on separately. Is there any way to separate them from Main head lights.
thats odd, the marea is ment to light dipped uf you put full on so thats correct.
i assume maybe your stalk control is broken?
Hej Man
My knowledge of Carz is very limited. Can U plz I can find the stalk control and wht is its function?
Waiting for ur reply
im assuming he's refering to the stick at the side of the steering wheel (the one for the indicators) its possible the little internal micro switch for the diped beam has had it (do the side/parking lamps work?)
I hve checked the stick at the side of the steering wheel. Both the side and parkerings lamps are working! Then there must not be anything wrong with it or ?
By d way.. thanks for giving ur time
