jopan53
Dear Members
The injection pump of my Hymer B654 - 2.8 JTD engine - YOC 2001 - leaks and need to be replaced.
Doing so a lot of stuff has to be removed: timing belt, etc. Hence, it is the right time to replace the timing belt set as well. I ordered already the injection pump and timing belt set, which I have replaced 3 times before.
As the motor has 150.000km and the water pump has never been replaced, I also feel that it is the right time to replace the pump as well. However, due to the compactness of the motor compartment, it is for me impossible to see which brand of water pump is installed.
Searching for a replacement pump I see +50 different suppliers with slightly different shapes of pumps. Are all those pumps 100% compatible with the original installed and will they fit without modifications.
As replacing a leaking 2.8 JTD water pump is a major job, I would go for a well know brand like INA # 538046910 or SKF VKPC 82652.
Due to time constraints, I am obliged to have all spare parts on hand before I carry out the revision. Any advice if those pumps or any other quality pump would fit, without modifications, is welcome.
Thanking you in advance
Jozef
Jozef
