Technical  Water Nosie Behind Dashboard in mk2 punto
Hamada
And it increases when i rev the engine
I only began to hearing that noise after someone opened up the cap from where you top up the coolant
would you explain a little bit more please how to bleed the system
Top of the radiator is yellow screw, turn by hand. Open untill coolant is flowing then tighten back up, then unscrew the small bleed screw on the hose going into the actual car (behind the coilpacks on the right side of the engine) and same again.
Make sure there is plenty of coolant in the resevoir and renew with 50/50 coolant and water.
Not just water alone. Have the nose of the car higher up on an incline and air bubble should shift.
should be the engine running during the whole process?
The engine should be running and up to operating temperature. (Cooling fans kicked on, thermostat open.)
Go slowly opening the bleed valves, the coolant will be about 90 degrees C and will be under pressure. Be careful while doing this.
