ScottieCinq
A month or so ago my cooling fan stopped working, I took it to the garage and they told me that it was the switch. They replaced it and said it was working-it wasn't. I took it back and they then said that it was be the thermostat, they replaced this and then it worked. Then got the car back and realised that it was losing water, going from max-min in around 80 miles, sometimes less. Took it back to garage and they said that they could not see any visible leaks from the hoses or the block, the only thing they could see was form the temperature sender and they took it out and put PTFE tape around thread and they said it wa ssorted. Low and behold it isn't. Now I'm getting fed up as this is getting costly, so far £80!
Can anyone think what this might be or has similar problems so I can try and poin the garage in the wrong direction, my GF really needs the car for work so we are still using it and checking the water after every journey, which isn't very practical.
HELP please
Thanks in anticaption.
HELP please
