Technical Water Ingress - N/S Footwell - Qubo
flopro
Hi - This is the 1st time I've posted a thread so go easy on me?
I removed/refitted the front windscreen plastic scuttle valance recently to replace a broken front spring and top struct bearings and since I have found water leaking into the cabin onto the rubber matting in the nearside footwell.
When I removed the plastic scuttle I broke a couple of the plastic clips and these need to be replaced at some point primarily as i noticed that the edge of the scuttle that abuts the windscreen is made of rubber and appears to be securely fastened to provide an effective water seal (which is perhaps the cause of the problem)
1st question - where can i find a part number for these clips and/or a supplier?
2nd question - has anyone experienced the same problem of water ingress and found a solution
TIA - I would really appreciate any advice from the guys and gals on this forum?
Many thanks
