Washers stopped working
P
Paul
I have a 1998 Bravo HGT and the washers have stopped working (front and rear). The pumps make no sound whatsoever. The wipers work so its not the fuse since they share a common one. Do the washer motors run through a relay (if so which one and where) or any other ideas what is wrong? Duff motors would be an idea but both going at once is a bit strange.
Hi Paul,
The front and back washers are powered by the same pump as far as i know, which might suggest your pump is knackered alright.
Cheers,
Colm.
Exactly
There is only one pump. It turns one way for the front and the other way for the back; all controlled by one way valves (these sometimes fail).
So my guess is pump failure.
Headlamp washers??
What about the headlamp washers? Both the front and rear screen washers are working, but not the headlamp washers. Help appreciated.
I think its something else..
Hi folks,
I think it's a relay/wire off problem as if I pull the stalk on the column towards me nothing happens and I get 0 voltage at the washer. If I push away, the rear wiper activates but no washer. SO my guess it's either a relay, a wire fallen off, or a problem with the stalk itself. Any ideas which relay the washers operate through or where to start looking?
This is kind of urgent as I have someone about to buy it!!!
Cheers,
Paul.
M
7K
mick gibbons
M
T
524
Thomas
T
M
418
M
3
1K
Dark Lurker
