General washer bottle
takeaflight
Hi All
Wonder if anyone can help, the window washers stopped working on my motorhome based 2000 2.8TD Ducato.
The electric motor is working I have sucked and blown down the pipe from the bottom of the bottle to prime the pump. I can get a slight trickle by sucking but thats about it.
Thanks Roy
Bigbloke55
If the washer pump has a pick up pipe check to see if it has a filter at the bottom of the pipe. If it does check for blockages or is it clogged up.
REG_UK
Re: windscreen washer poor
I also have the same problem but on a Ducato 14. The output is very frothy. Did this problem get resolved?
Thanks.
REG
