Tuning Wanted a K & N filter.
hello lads anyone out there got a k n air filter chrome fitment to fit my lancia y10 carb model 998 fire model thanks regards dave
will try get a picture for you not to sure of method lol, car only done 23k from new all original, underneath as new, reason I want to try kn filter car got a flat spot just want to see if it eradicates it I suspect advance and retard vacuum in distributor not working at the moment that's plugged and 80per cent improvement thanks dave
how much mate, was going to keep her std but if the price is right as they say, enlighten me the 4x4 cam is it a higher profile and carb to suit thanks dave
The profile is slightly different giving a fraction more exhaust so you can get more air and fuel in. Compared to the 45bhp the standard Panda made the 4x4 was rated at 52bhp but had a much smoother torque curve.
Carb' and cam' £50 posted?
Delete your phone number chap. This is a public forum. I'll send you a pm in the morning with my email address so you can use paypal. That way I'll have your address in the checkout. :)
Some pictures of the K&N. Its had a hole drilled in the top and rubber bung inserted so you can plug the pipe that goes into the back of the airbox into the filter. PM sent on postage
Hey Dave Heres some mug shots of the Y10 parcel shelves. There's not much to choose between them really. One is brown and the other black, both out of series 1 cars. They both have the flexi cords in place that attach to the hatch and pull it up when you open the hatch.
carb and cam here, took cam to work today had a good luck one lobe is totally flat compared to the other 7 one of the engineers put the verniers on it unless I get it reprofiled its totally useless, one valve is not going to operate the same as the other 7 stay, ie open longer not open as far I,ll get a price to do the one lobe but don't think its worth doing dave
went into local engineers to get price on reprofiling that one lobe not worth it,also I asked him to show me how to measure lobe height its turns out this cam is a standard height of 7mm the 4x4 cam should be 8mm is it possible you,ve sent the wrong cam thanks dave
