My punto has developed a vibrating when I touch the brake pedal even if I only just touch the pedal but only while over 15mph. The noise/feeling continues after I let go of the pedal for a second.
It felt like it was coming from the front nearside so I checked the brakes on that side and everything seemed fine. Then I realised the ABS pump is on that side, if I remove the maxi fuse for the pump I get the handbrake light and abs light but brakes feel fine.
I tried bleeding the brakes to see if there was air in the pump but one of the rear bleed nipples have broken.
Any suggestions?
Thanks,
Dan
Any suggestions?
Thanks,
Dan
