No point arguing about oil... usually "everyone" is right!
First of all, the oil your car needs is going to be listed in the handbook. The grade (5W/40 or 10W40 or whatever)... plus any specifications it must meet. The main one is the API rating which is S/x where x is a letter of the alphabet. Probably S/G or S/H.
The Fiat rating also applies... though this is specific to Fiat and if an oil isn't rated as meeting that standard it may just mean that the oil hasn't been verified to meet it, rather than it doesn't.
The Fiat rating relates to additives. The ACEA C3/C4.. etc. is also to do with additives, just more general ones.
So... you need an oil that is 10/40 or whatever and betters API S/G, S/H etc... that has the ACEA C3/4 and the Fiat spec' on the side of the packet.
The good news is that it is practically impossible to buy an oil that doesn't meet this spec. Even "Halfords" oil (semi-synthetic in 10W40) is API S/L and ACEA C3. It doesn't have the extra few Fiat spec'... but will it wreck your engine....? Not much chance.
The ratings API/ACEA and Fiat spec's only relate to the oil when it's new. They don't tell you what else is in the oil. Cheaper oils are inferior to expensive oils because they contain less other additives (not written on the pack.. you need to look at the manufacturers' data sheet) that keep the oil stable.
Oil breaks down in use and usually it gets thinner. Cheap 10W40 will be more like 5W30 after a few thousand miles... hence old oil is more likely to lead to engine wear (part of the reason why you change it) and is more likely to burn off, being thinner... Synthetic oil is better in this respect than semi-synthetic... (it will also be API S/M or and ACEA C3/4).
Garages use big drums of the same stuff you buy for £10 a litre over the parts counter. They pay about £2 a litre for it in that size and they charge you £10 a litre... so there's no need for them to put inferior oil in your car..
Whether it's got all the spec's that the TA engine in particular needs is a different matter... but we already decided that's not fatal.
So.. to the OP... I'd change the oil. Use a quality brand (Motul, Fuchs, Silkolene etc.) that meets the spec' you need and see how you get on. Synthetic will stay more consistent than semi-sythetic but use whatever grade the manual says. I'd be less worried about the Fiat spec' but I don't know what it brings to the party...
Consumption should drop with new oil... but do have a peek under the beast for leaks. If it's not burning it, it might be sneaking out somewhere round the back..
Ralf S.
