Technical URGENT - stripping seicento rear drums
Bravissimo
Nottingham, United Kingdo
I'm attempting to strip down a rear drum from a 51 plate seicento 1.1 and I'm stuck - like the brakes !
I've taken the wheel off and the locating bolts and the hub centre nut but can't get the drum off or see anything that looks like it would release it.
Can anyone tell me where I'm going wrong or what I should be doing ?
Gav
GhostWKD
Winning
Banbury, Oxfordshire
hub centre nut shouldnt have to come off for the drum to come off, the drum is probably just very very stiff (they all are), had to remove a few of mine with wooden block and a hammer/screwdriver :eek:
GhostWKD
Winning
Yep, so long as you have got the two retaining bolts off thats all that holds the drum on (y)
Edit: although remember you dont want to shatter the drum :eek: hence recommendation of block of wood and hammer :p
smurfhead
Huddersfield
Put the centre nut on otherwise you will have to play around with the wheel bearing, but as Alex says, just beat the hell out of it til it falls off.
