Ok, first of all, I adore mi fiat gp (even though is a 4 door 1.4 8v active) I love it and even my girlfriend is jealous of it I've had some issues since i bought it (jan 2011) like check engine or start/stop not working properly but all of them went away with a night without battery. I havent had any incidents until some 2 weeks ago.
It all started with the start stop system not letting the car off for more than 10 seconds before bringing the engine back to life.... then 2 days ago the engine didn't stop at all in red lights. I researched this and i found out that the system wont work if the battery has low voltage so i figured that it was because i fitted fog lamps, 2 amps and a pioneer hu.... i thought that all this aftermarket stuff was using more energy than what the battery+alternator could deliver, so I unplugged everything (even the HU)... today in the morning my battery was DEAD!!!
The fuel pump worked, all the dash lights came on, but the starter didnt engage (i could hear the solenoid) and as i turned the key to start the engine all the dash tickled (as always when u have low batt).
Solution? I had to do a rolling start backwards (my street is inclined and m gp was facing upwards :bang: ).... i had to do 3 rolling starts during the day (im exhausted) and when i got home i started figuring out how to determine what was causing the battery drain (i thought that it was some of the stuff that i had fitted, but it wasn't).
What I did was to unplug the negative frome the battery and conected a "test light" (i used a 12v led strip i had). As i suspected the leds turned on.... so i left it there and start taking one by one the fuses and relays, hoping that the problem was a stuck relay or something easy..... So i spent like 20 minutes trying all the fuses inside the car and then tried the ones in the engine compartment.
I did find the fuse with which by removing it turned the leds off .... the problem is that it is a huuuge fuse.. its a 70 amp maxi fuse.
I looked at the owners manual to find out what circuit that fuse protected but it didn't say... i think it has to do with something important in the engine but i dont know where to start
PLEASE HELP ME!!!
i'm gonna upload some photos of the fuse
ps. sorry for my bad english, I'm from CHILE! :slayer:
When I pulled this Fuse the test light turned off, so i know that there is something in this fuse's circuit that is making short.
PLEASE HELP ME!!!
