General Updating Fiat Panda Connect Nav+?
JanGroen
Hello,
I have aFiat Panda (08-2006) with the original Fiat Connect Nav+ navigation system. Thelatest maps are form 2010-2011.
On theinternet I read that it is possible to update the system (firmware) so you canuse 2013-2014 RT3 maps (from Alfa / Peugeot / Citroen).
Can youtell me if that is right?
Personally I would be very carefull with firmware that's not designed for the hardware.
The Internet gives no guarantee:rolleyes:
Rare option though. Does it work ok? I had CN+ on my Stilo (also 2011 as latest update) and I kind a miss it.
gr J
I don't think it was ever an option in the UK (well, I've never seen a UK Panda with it fitted) so you might not get an answer on here as most people seem to be UK based.
However, as a general rule, flashing firmware to devices it wasn't designed for can go horribly wrong and turn things into expensive paperweights.
I’m nottalking about installing firmware on the Connect Nav+ system that is not designedfor it. I was wondering if you can use the RT3 maps when you have installed thelatest original firmware on the Connect Nav+ system.
I don’teven know which firmware version I have on my Connect Nav+. Does anyone know how I can see the version?
