General update on the cinq
arc
this is where i stand
Manchester
and i had this pesky thing removed and modified so that if needs be it can be re-attached :)
:devil:
its not entirely what i had in mind (need to alter the centre section after the decat a bit) but for now, tis good :D
and heres a peek at the next bit:
it's a supersprint manifold, slightly modded to allow the cat to be put back on if needed :)
i like red inlet manifolds, you can *just* see the SPI manifold thats on at the mo, and thats red :)
It's a shame it gets covered by so many tubes and pipes. Anything else going red? Rocker cover?
I must say you will feel a big difference without the moggy. I think my exhaust doesn't have enough back pressure and the engine runs better with the cat than without. Doesn't do any good for the MPG though :(
i have a red cam cover, and used to have it on my 1108 - but i think its too much red with that on. I was going to paint the fuel rail on the MPI setup in black, but i think it looks ace as it is now :)
my exahust should be ok for back pressure, as its a supersprint manifold and a supersprint backbox. supersprint do a decat centre section, so im guessin it works well without the cat :)
