General uno turbo discs
As far as I know, the turbo models both Mk1 and Mk2 use double ventilated discs, due to larger engine. This leads to another wheel offset, and you will not be able to use your (very nice I think) fox alloy wheels - they'll come too far out. My alloys are from a Fiat Ritmo (UK: Strada) Abarth 130 TC (if anyone knows it) with huge double ventilated discs at the front. The offset differs about one inch from the single disc'ed not TC Ritmo.
Morten. Please correct me anyone if I'm wrong.
Abarth alloys. Inter Alloy lowering. Phoenix Gold & Kenwood audio. Abarth steering wheel. Insane Dalmatian door and seat refurnishing
Projects: K&N induction kit, racing seats, exhaust, window tinting.
whats wrong with the wheels comin out further? surely if they are on tight and dont wobble or anything then they will be ok? mine are already quite far out compared to the normal wheels
Uno "Fire" 999cc
Lowered 40mm Uprated Gmax shock & Spring system
Fox Evo3 15" Alloy Wheels
3" Rage Backbox
Corbeau Clubmans
E-Tech hatch Spoiler
2x 450W 12" Custom Built Bass Box
800W 6x9s
300W & 500W Amps
Click here for photos
You can't use vented discs with standard calipers, and if your calipers sit as close to the wheel as the ones on my girlfriends Panda do (similar calipers to the ones found on regular Unos) theres no way you can squeeze the much bigger calipers for the vented discs in there. But since you have aftermarket wheels, it would be worth a bit of investigating to see if it all could be done. But I cannot stress enough that standard calipers simply don't have enough width to take vented discs. Besides, standard Uno calipers are designed for 227 mm discs (in diameter) and Uno Turbos use 240 mm ones.
I've just checked it on Ebay and they are listed as Red Dot/TarOx... which is about the same as a big sign telling u to step away from the deal. The 1st thing you could read when you went into the TarOx english website about a month ago was a big banner stating that TarOx and Red Dot is NOT the same thing, unlike some ppl tried to make their customers believe.
Goncalo D.
well have 15" wheels. there is a bit of space for bigger disks or calipers so i suppose it could be done. I want to get rear diskbrakes tho really... dunno why, just do lol.. they look nice.
just painted my drums and calipers red tho.. looks great
Uno "Fire" 999cc
3" Rage Backbox
Corbeau Clubmans
800W 6x9s
300W & 500W Amps
Bushboy,
Our little Unos are neither fast enough nor heavy enough with a 999cc engine to warrent all round discs or oversized front discs!
Paul
yeah but they look good heh. ok im not to bothered about the front but the backs need doin if u ask me. the way my cars goin, ital be a turbo replica soon lol... will get the engine turboed oneday in like 10 years... although i wont have the car then and im sure ital be on a heap of crap cars
Uno "Fire" 999cc
3" Rage Backbox
Corbeau Clubmans
800W 6x9s
300W & 500W Amps
You can't fit the discs on the rear stock axle...you need to swap the whole one from a Turbo modelB)!The same problem occurs for the front brakes:the Turbo calipers (and discs) can't be fitted on the standard hub carriers, so you need to swap them:)
Passion has neither brands nor models!
La passione non ha nè marche nè modelli!
well i have thought about gettin a turbo and nearly went to check out out bit changed my mind cause the insurance would bhe terrible
Uno "Fire" 999cc
3" Rage Backbox
Corbeau Clubmans
800W 6x9s
300W & 500W Amps
If you haven't past your test ahave you yet driven your uno? If so, how much is your insurance costing?
yup loads of times... but usualy only when ive changed somethin and i need to take it around the block to see if it still works lol
Uno "Fire" 999cc
3" Rage Backbox
Corbeau Clubmans
800W 6x9s
300W & 500W Amps
