- Joined
- Sep 2, 2007
- Messages
- 126
- Points
- 112
I have a (common) problem with my Uno cutting out without warning . It runs perfectly for about 20 mins driving and then just dies. Won't restart for about half an hour while it cools down or resets itself (or that's how it seems), and when running again cuts out after only a few more minutes.
Change the electronic ignition module I hear you all shout! . Well I have done along with recently fitting new HT leads and spark plugs. Also, a new distributor cap and rotor arm and substituting a different coil but no difference.
In one of the earlier threads with the same issue (started by UnoMia), replacing a sensor in the distributor was mentioned but not sure where what this looks like, or if it is likely to be the culprit.
The engine turns over and almost fires up so wondering if it could be a fuel problem, such as a clogged fuel filter, worn injectors or fuel pump on the way out . (mIne is the 1108cc engine with single point fuel injection). Also the vacuum advance unit but is this more to do with uneven idling?
Any thoughts or ideas welcome - the list of possible causes is quite long judging by previous threads but at least I have covered a fair number already.
Cheers,
Andy
Cheers,
Andy
