CDI? I presume you mean the finned box on the side of the distributor. Scooters have CDI...
Does the engine sound 'normal' when cranking over? If it makes an uneven stirring sound you need to first look inside the oil filler with a torch, to make sure the camshaft is turning (need I say more...
If the cranking sound is uneven but cam is turning, then suspect blown head gasket as Morty describes.
If engine sounds normal you have, presumably, removed a spark plug and had an assistant hold it against engine with insulated pliers... check for spark while cranking.
If spark is OK then you need to see if plugs are getting wet after prolonged cranking with choke, multiple stamps on accelerator, etc. If no sign of petrol then take the air cleaner off and watch carburettor barrel while you operate throttle linkage. Should be a strong squirt of petrol. No squirt suggests that carburettor may be empty - suspect fuel pump. Take off fuel cap to ensure no vacuum in tank.
Recently when I tried to start up my Uno after head gasket replacement, I had a major problem with flooding. Symptoms were that everything seemed perfect but engine just wouldn't start. Solution was to hold accelerator all the way down, and keep cranking until started.
I had an Uno 70SL a few years ago that sometimes wouldn't start unless the accelerator was held down as above to 'dry it out'. The problem was eventually traced to the inlet manifold gaskets leaking water into the cylinders. A pleasant discovery because it was much simpler to fix than a head gasket!
-Alex
