thanks dutchie.. soo far the car is very much smoother as compared to the viberationing and missin engine before i got the valves clearance adjusted..
although there is a significant improvement .. there is still some of the problem remaining.. i would say almost 85% of the problem is gone...
I had some time at home and i used it to convert the inches scale they were using on the feeler gauge to the mm value, which was shown in porter manual. :idea:
here's what i found .. my new setting is.. Inlet 0.012 inches (0.3048 mm) and Exhaust 0.014 inches (0.3555 mm).. but Porter manual said, for Inlet 0.3 mm and for Exhaust 0.4 mm..
question is of exhaust clearance.. 0.014inches/0.3555mm is a bit less than 0.40mm because 0.015inches = 0.3809 mm
please tell me if i should keep it to 0.014inch or get it changed to 0.015.. which would be even more wider then and as far as i think will get rid of heating problem i was facing in summers.. :idea:
secondly the dude at garage told me to add a little bit of engine oil with diesel in my tank .. like when i get a full tank i should add about a litre of oil with it.. this will clean the diesel pump.. he recommended this to be done once or twice.. i did that before coming to work .. think there is somewhat of more smoothness
