trublue
Hi guys, I'm new to this forum.
This question has probably been asked many, many times before (apologies) but what are the most likely causes of a 93 (L plate) 1.0ie Uno idling erratically and cutting out when hot?
The engine runs fine until it's been going for half an hour or so, then when pulling up at lights the idling rate increases, then drops before dying altogether. It can be restarted after waiting a couple of minutes, then may or may not happen again. It's usually OK if it can be kept moving/revved when stationary.
I am probably going to try changing the distributor first as it reminds me of a problem I had with an older Uno where it would not start at all unless cool. Also, reading some other posts on the forum would suggest this is quite a common cause of trouble.
However, with this being a more recent model, is it more likely to be the engine management system - lambda/airflow sensors? I am reluctant to spend money on diagnostics at a main dealer as it ain't cheap!
Any advice gratefully received.
