tyres sizes
tyres sizes
R
rsmallwo
Can i replace the 175/65/R14 tyres on the front with 185/60/R14 tyres.
The rear tyres will still be 175 width. Anyone done this, is it still ok?
Tyre circumference is only 0.5% different, I'm more concerned about having ever so slightly wider tyres on the front than the back.
wider tyres should always be at the back to reduce the car tramlining/being dragged around.
Would'nt normaly agree with that - tramlining only an issue on excessivly wide tyres and/or worn suspension/hub components. 185 is not OTT in this case and little different from the 175's already fitted.
Like nearly all FWD cars, Bravo/a's are nose-heavy balance, so having slightly wider tyres on the front would make more sense, assuming the tyres were at least as good quality/condition as the 175 rears and the tread depth adaquate.
I run my lightly-laden FWD Daihatsu on 165/60 fronts and 155/65 rears with no problems - as long as both sides of the same 'axle' have the same tyre size, (and pref. pattern) fitted, then no worries.
J
5
642
jords
J
M
1
544
S
K
5
942
Tommy K
T
M
1
330
Jason
J
