I changed the tyre size on my 1993 TD10 from the factory issue 185/80R14 to 195/70R14 as the standard tyres were becoming hard to source here in Almeria. Then I found out that the spare wheel would no longer fit in the underbonnet cradle which is only just wide enough for the standard tyre, the extra 10mm being too much. So now it has to live inside, something of a nuisance at times. I checked with the vehicle testing centre before making this change, and the rolling diameter was found to be within their permitted tolerance, but they told me that 205/70R14 would NOT be allowed and would cause a test failure. Be warned!
