Technical Turning over but not starting
tmccar
My 2001 Punto MK2 stopped while driving along and would not restart. I thought it was related to the battery (which is near end-of-life) or the alternator. But when the breakdown guy connected a booster to the battery, it turned over ok but still would not start.
What could have caused it to stop like this?
Hmmm
Sudden loss of the engine and failure to restart under any circumstance
I had a sneaking suspicion that it might be the crank sensor
pop a HT lead off with a scrap but working plug, and check for presence of spark
if there is no spark - it points to crank
if the plugs are wet tho - with fuel - its not crank, as the crank tells both injection and ignition phases
Ziggy
OP
OP
T
tmccar
Ok thanks Ziggy, I will check. I'm 2 hours from the car at the moment (I borrowed my mother's car to go to work) so it may be a few days before I get a chance to check.
Also make sure the yellow key "code" light goes out on the first click of the ignition which indicates the immobiliser is working correctly
oldhammer
Busy rebuilding pand'a
manchester'ish'
You need to work out what is missing;
is Fuel getting there?
is there a spark at the plug's.?
is this a 16valve., if so check the airbox hasnt worked the connector on top of coil free,
this happend to me once,
OP
OP
T
tmccar
Yes, I know I should have checked this already. But the breakdown guy said he thought that the timing had slipped so most of my time on Saturday afternoonwas taken up in removing the timing cover and checking the timing marks.
As it turns out, the timing looks ok although the belt was a little slack, so tightened it.
I will check fuel and spark when I get back to it on Friday evening.
i assume you already checked this, but i had the same problem, and for me it was solved with reconnecting the two connectors on the ecu.
i hope this helps you.
OP
OP
T
tmccar
I didn't but I will check that if the crank sensor doesn't make a difference, thanks
OP
OP
T
tmccar
Ok, I've changed the crank sensor but it nade no difference (still no apark). Fuel is getting through OK
OP
OP
T
tmccar
But wouldn't it make an effort to fire up? It's not firing at all
OP
OP
T
tmccar
I disconnected the feed to the fuel rail, turned over the engine and there is plenty of fuel coming to this point.
OP
OP
T
tmccar
Could this be caused by a faulty coil pack? Or would there still be some firing?
oldhammer
manchester'ish'
Have you not got scrap yard nearby?
if so grab a coil pack, and swap them over 1 at atime & see what happens.
this new cranksensor you replaced was it a new one?
sometimes brand new parts can be faulty..
OP
OP
T
tmccar
Yes, brand new. I have a donor car now, and I will swap the sensor from that and try it. Failing that, I will try swapping coil packs.
