Hello!
My 1.2 is still not turbo, but I was wondering about possible problems with the standard clutch.
Two guys that I know made turbo conversions and have big big clutch slipping problems.
One engine is a 1.2 bored to almost 1.4 with tjet pistons but standard crank, so it's more a 1.3 , other is a tjet with normal fire gearbox (I always make confusion with C510 - c514).
The 1.3 has an used 200mm flywheel with it's clutch, the tjet has a copper clutch with standard pressure plate (bad choice in my opinion but the clutch guy thinked it will be fine) and both are slipping like hell with the TD04 turbo at 0,5 bar (so really not very much hp).
How this could be?
I never heard about this big terrbile clutch problems in any 1.2 conversion, but I know if you're going really hard with hp the standard clutch isn't enough, but we're talking about over 200nm and I think over 140 hp, and that's a lot, and they're not reached with a td04 at 0,5 bar.
What's your experience?
I always knew that the standard clutch should be enough for me but now I started to worry about and would'nt like to buy a new standard clutch and then have it slipping when turbo goes in (now it's burn by too much drags and slips even without turbo).
How this could be?
