Scottmannthenewbie
Hey all, new here and just signed up after buying a high top doblo 2009 1.9 diesel from a friend that has not been looked after very well!
Plan is to turn it into a cycle collection vehicle ( I run an ebike shop in Torquay)
It's been messed with by multiple idiots, partly good as it has had tons of new parts thrown at it!
On the turbo there's an actuator vacuum hose which has worn/split/snapped and hanging down.... where should it go?? I know it needs to go to the control valve but where is said valve located? I've found a valve by the bottom left of the battery box which has a 2 pin plug and a hard plastic pipe disappearing into the block and a hose that has a neatly cut end... but that hose isn't the same as the type on the actuator so guessing it's a tank vent valve?
Thanks for your help, looking forward to getting this running!
