I just wondered if anyone know where the spark plugs are on a mk2 ulysse. I have searched the net high and low for manuals or advise and cannot find anything.
I have a mis fire problem with cylinder number 1 and need to check everything with that cylinder.
Looking at Peugeot Service Box ( http://public.servicebox.peugeot.com/ ) the plugs are between the two cam covers on top of the head. They are covered by a metal or plastic module which appears to incorporate the plug leads. At the opposite end to the oil filler cap there will be a connector - and a bit to the left of this a 6mm longish bolt or set screw holding it all to the head. Within this unit is also the ignition coil.
BYW, Service box doesn't include procedures, just diagrams - you have to register (in French, not difficult) to sign up for it. Ask if you have a problem!
