Hi - yes I can use the oil thrower interchangeably as its easier to mount the trigger wheel to an 850 thrower - rebalanced - really this isn't a trigger but a belt driven timing wheel - its the trigger sensor / cpu set up I m wanting info on
Are you after info for an ecu so a crank sensor set up. Because the 899cc cinquecento has an end pulley set up with the crank sensor gaps and the timing chain cover has the mounts for the crank sensor pickup.
Tim
