Totally Off Topic- PC (Powerstrip) Help Needed!
B
Ben B
I know I should really post this on a Powerstrip or at least some kind of PC based forum, but I need some advice pretty quick, and I know how busy this forum can be compared to others!
I use Powerstrip on a PC through to a CRT widescreen telly in my room, (for giving me a screen res that suits 16:9 ratio in case people aren't familiar with Powerstrip) The screen is pretty unclear, but it's usable!
I've just installed a game that was recommeneded to me, (Battlefield 1942) however it didn't like the res I had it set to, so I right clicked Powerstrip in the task bar and selected another mode. This immediately made Battlefield spring into life (only on the menus, it still didn't like the res when I tried starting a game) but when I returned to windows, the screen is almost completely black with garbled junk at the top.
Every time I restart windows it works for a moment until Powerstrip has had time to start, then it does the inevitable and screws up the screen again.
What I need to know is, is there any way of disabling windows startup items? by, say, holding a certain key or anything? Or is there a shortcut I can push to switch modes in Powerstrip? I need something I can push without being able to see the screen!
I hope that makes sense! Hope someone can advise!
Ben B
press F8 whilst the pc is starting and select start in safe mode.
go start -> run and type msconfig
goto startup and untick whatever you think is causing the problem, ok it then restart the pc. it should restart without what you turned off.
most likly your monitor dosnt support the combination of your desktop refresh rate with your resolution
That's done it! I'll have to remember that for the future!
Safe mode prompted me to system restore, and that sorted me out!
Ben B
P
1
315
Andy1.6hlx
A
J
3
472
K
3
1K
Tommy K
T
