The top mount is not fixed into the car, it just stays due to weight of the car. There is a large washer on the top, which stops it falling out.
I'm guessing the stands are under the chassis/body of the car, not the suspension arms. The strut will have then dropped to sit on those washers, and if lifted, you can lift it back into its fitted position. This is normal and not indicative of any fault. It does still cause some MOT testers to wrongly fail these and other similar vehicles.
The rubber of the top mounts does fail with age, but slowly of course. Difficult to test, with it not being secured, but with the weight of the car on its wheels, it needs a visual check from the top to see if they 'look right'. They should at least both look the same. Height differences, or one being furher back than the other are good indications of a replacement need. With the car on its wheels, pushing down on the wing and watching the flex can also be an indication of its condition.
