Hi I am new here, although I have owned Tipo's and been a Tipo fan for many years. Infact since they were launched in 1988!
I have a problem with the Tipo I currently drive. Its a 1.4 carburettor model with a manual choke, registered in 1989 on a F plate with around 55K miles. If I start it when the engine is hot it runs very rough and will stall as soon as the engine revs drop at road junctions etc.
It starts and runs from cold perfectly, only needing minimal choke, but its like a different car when started from hot. The only way I can keep it running is to use lots of choke to increase the idle speed to stop it stalling.
It has a basic electronic set up, with some kind of ECU on the distributor and also an electronic box inside the near side front wing. Could this be at fault as the plugs are clean and it runs well?
can anyone shed any light on this problem?
Many thanks!
Many thanks!
