TinyXP + Messenger
TinyXP + Messenger
install messenger 7.5, and run it in win2k compatbility mode instead. i assume you're trying for minimal resource use if you've put tinyxp on.
Didn't work. :(
Pretty crappy old PC so though cut back windows woud be good for it. It has made a big difference in performance but it's got a few issues I'm slowly trying to work around.
i used to use TinyXP and it was fine with MSN, however, it was quite an old release.
i cant see anything on google so it doesnt look like a common issue, it must be something with your network setup.
possibly incorrect default gateway?
if your desperate sign in to eMessenger or try using trillian to connect to the msn network
Ry
