Hello,
1.2 2007 Grande Punto
I am having trouble getting the timing right in a grande punto. Basically, the car was purchased with a bad water pump. The water pump was so loose I am assuming the timing has been knocked out as the car has a bad misfire.
Worth noting I have changed spark plugs, leads and coil pack. Also done a compression test on each cylinder which brought back readings between 230 and 250.
After much fiddling about last week I read online my Cam required the tool to set it as there is no Cam markings as my Cam is the one with the torx end.
So, I got the timing tools. I can get the crank to TDC using the flywheel readings. TDC however does not line up with the crank locking tool it’s around 90 degrees out.
When I set the crank to TDC is locks the Cam. When I move the crank away from TDC it allows me to get the Cam tool in place however, when I put the tool in place it locks the crank and stops it going to TDC by around 5mm. The only way to get the crank freely moving 360 degrees is turning the Cam upside down.
Any thoughts or help appreciated. Thanks
