Take some pictures and write a guide for others. I did mine a while ago but didn't take any pictures.
Definitely change the water pump and tensioners while you have it all apart. Cam sprocket has to come off but it is keyed so only goes on one way round. Loosen the bolt in the center of the cam sprocket while the cam belt is still on to avoid hitting valves. It is not very tight and a large screwdriver through the spoke and onto the small ledge behind it is enough to hold it.
Remove engine ECU, water header tank and wheel arch trim first to give you space to work. On the crank shaft pulley, undo the 4 Torx bolts to take the pulley off. You dont need to lock the crankshaft or undo the center bolt like some cars.
Setting the tension on the new cam belt tensioner is a 2 person job. One to push the little leaver from below and the other to tighten the center bolt from above.
You need socket set, Torx key set, Strong Hex key(I think 5mm) to remove cam position sensor and a large adjustable spanner or open ended spanner to release the Aux belt tensioner.
Don't forget all the bleed points in the water pipes and one in the Rad when you put the water back in.
Have fun.
