punto_lad
is a 55 body different to a 60 punto. local scrap yard have 2 55's but none off a 60, are they different bore or are they the same?
cheers in advance
scott
cheers in advance
scott
you only use the bottom bit of a 75faster4_tec said:a 75 TB is for a MPI car, and hence doesn't have an injector in the TB like the 55 and 60's do.
arc said:jsut to clear things up..
punto55 and punto60 tb can be bored out to 40mm. The throat is pretty much totally removed and resleeved, so the origonal size does not matter.
the mpi tb can be fitted, but its not quite as straightforward. check the cinq forums, a thread by DJ_Bucho. Details it well
