Technical Throttle Body Connections
arseofbox
Principality Retained :)
Midlands
Right, strange one here.
My Punto 60 (Maybe 75) Throttle Body has a problem....its not on the car!
One of the brass barbed connections has been sawn off by the numpty that took it out the scrapped car..
It looks as though(or Im presuming) its pressed in. I reckon If I could drill accurately (I cant), I could drill it out then press in a copper or brass pipe (matched for diameter but w\o barb) to replace it. I cant be arsed finding another TB, and I cant afford to buy one!![V]
Tom (AofB)
95 Cinq Sporting - Rattly GrpN Catback Exhaust, <font color="black">Buckets</font id="black"> and 3pt Harnesses,Sexy VW styleé dials (that look great, but dont work!! :)D)), 10" Sub and 6x9's, ETech Wing. Lots of Dirt!
1242cc Engine in car, not starting, boot delock soon, K+N still in garage!
i have a cinq TB available if you want it?
The Man that Can
well sod the cleanliness, i was probably going to tap it anyway!
Brick, its a Punto 60 TB im hunting for!
Tom (AofB)
OK, God.....how would I do that!?
Answers on a postcard please!
Tom (AofB)
Im not using an induction kit.
Its not vacuum or fuel feed!
Its the back coolant feed!
Tom (AofB)
Who connect the coolant lines to the TB anyways unless you live in a very cold place. I diconnected mine on a 300zx while i was in Canada and only change was a rougher idle on cold days until engine warmed up(yes it is the same Z i have now):D.
What Bypass it full stop?
As in both front and back feeds?
Tom (AofB)
Erm. Slight prob....
Just found its not the coolant hose as I stated before. Its the Charcoal Filter Line.
Could I just double up on another vacuum port, or use the hot \ cold air selector?
Tom (AofB)
So using the Hot\Cold selector is OK?
Tom (AofB)
