Technical Throttle advice
desi
hi, my car does not start 1.2 v8 2003 and I done all the checks, it already had new battery put in last month and this week i changed the spark plugs leads and coils also the sensor because about 4months ago I had error code for misfire so that's why I changed it all and it need it but it was starting up and driving then but now car still does not start. I thought I check for error code but this was after I changed everything not before the car didn't start. but the misfire code has gone but only got 1 error code now and it is 'throttle/ pedal position sensor switch A' come up now. can that making the car not to start?
do I need to change the throttle body or should I just change the sensor which I found new 1 on ebay but only thing with that is I don't get how to take it out, do I just pull it out or push it from inside of the throttle body? :confused::confused: or should I just get 2nd had throttle body?
TDC sensor was the 1st thing I changed and it was working fine then after change.
What is the easy start trick??
