Derbyfella
Established member
It looks like the The 500c thermostat has gone or a hose
Please can you have a look and see what you think?
Yep - the large one anyway... cant easily get to the rear oneIs that hose tight that connects to the thermostat housing?
Pink or white crusting = thermostat failure.. change it asap don’t drive the car till it’s done!Yep - the large one anyway... cant easily get to the rear one
i am doing, cheersThe thermostat looks alloy if in doubt just replace it?
This is what I use .. pre mixed I’ve never used anything elsei am doing, cheers
Next thing then
Replacing the coolant etc
Halfords OAT 50/50 ok?
im not keen on halfords otherwise any OAT antifreeze and de-ionised water?
FFS I cannot get the radiator drain plug out….lost a socket in the front bumperPink or white crusting = thermostat failure.. change it asap don’t drive the car till it’s done!
You can get a thermostat that is all alloy so no plastic pipe that gets brittle over time! That’s the type I use
It’s either that or the large hose at the other side on the bottomFFS I cannot get the radiator drain plug out….lost a socket in the front bumper
is there anywhere else I can drain down from?
Brilliant…I got that clip off lost a few layers of skin…It’s either that or the large hose at the other side on the bottom
It has a clip you have to pop up first .. it can be tough to get off also so take your time & if you loose your rag … cool beer then back at it!
It does but waggle it! It’s a tough ****er but it will let go eventuallyBrilliant…I got that clip off lost a few layers of skin…
annoyed at myself really…jack is still in the boot which I can’t open cos ive removed the battery!
does that just pull off ie back towards the engine?
Yes but when it lets go you whack the back of your hand on the metal beam near by!Brilliant…I got that clip off lost a few layers of skin…
does that just pull off ie back towards the engine?haynes manual is showing a release clip?
I pulled off a little metal clip..presumably that’s what Haynes is trying to show.
Yup I have a bruise to prove it!Yes but when it lets go you whack the back of your hand on the metal beam near by!
It’s a black plastic L shape it will come off the rad.This whole thing?
Yeah, that’s what I thought.It’s a black plastic L shape it will come off the rad.
You have no excuse I’m a woman told you it was tough but it will let go! Try a large flat head screwdriver with a mallet… gentle gentle taps .. it may helpYeah, that’s what I thought.
It’s not moving either not helping as the cars on the deck and I can only get one hand to it. Oh and I’m weak
