A angie-B Member Joined Sep 20, 2004 Messages 406 Points 64 Location Blackpool (ish) Sep 22, 2004 #1 the button on my key has never worked, it may have done once but never since, why is this can anyone help?
Steven Patron member Parked in the garage Written a guide Joined Sep 26, 2003 Messages 23,879 Points 3,816 Location Northern Ireland Sep 22, 2004 #2 If you open it up you'll see it has a battery inside. Replace the battery and it should work again.
OP OP A angie-B Member Joined Sep 20, 2004 Messages 406 Points 64 Location Blackpool (ish) Sep 22, 2004 #3 tried that
Steven Patron member Parked in the garage Written a guide Joined Sep 26, 2003 Messages 23,879 Points 3,816 Location Northern Ireland Sep 22, 2004 #4 What do you drive again? Is it supposed to have remote central locking?
OP OP A angie-B Member Joined Sep 20, 2004 Messages 406 Points 64 Location Blackpool (ish) Sep 22, 2004 #5 its a Bravo, the key locked the car once but never did it again!
Steven Patron member Parked in the garage Written a guide Joined Sep 26, 2003 Messages 23,879 Points 3,816 Location Northern Ireland Sep 22, 2004 #6 Is the little red light flashing when you press the button? Maybe it's a fault in the car rather than keyfob.
OP OP A angie-B Member Joined Sep 20, 2004 Messages 406 Points 64 Location Blackpool (ish) Sep 22, 2004 #7 it was doing last night but it isnt today!! its a bit tempremental
polecat Patron member Written a guide Joined Nov 13, 2003 Messages 3,343 Points 558 Location Newcastle - upon - Tyne Sep 22, 2004 #8 The microswitch inside the key and the small actuating lever on the button are both likely to fail. If you open the key check to see that the lever operates the switch and that the red light comes on.
