Schuey fan
I,m trying to fit a temp gauge to 1.1 sporting (Schumacher) where can I fit the sender? it needs to be earthed. I expect that I will need to use an adapter, any suggestion as to where to get one?The sender has a 10mm diameter thread. Typical of a car manufacturer to fit a great big tacho but no water temp gauge on a car with a rad the size of a oil cooler, which from reading comments seems to be prone to overheating. The only warning you get of an overheat is a red light and a stinking anti freeze sauna from under the bonnet!
