Just after another avenue of suggestions for my ongoing electrical problems. I had intermittent failures with the rear lights - sometimes only one brake, sometimes one reverse etc, and have finally decided that it was simply dirty connectors. I have cleaned everything up with electrical connector fluid, and now have nearly everything up and running. My problem is that the taillights on both sides are still out. The foglights work fine, but can only be used when the headlights are on, rather than the front sidelights - if I don't manually turn them on, I've no light at the rear bar the registration lights.
All earths look ok - there are extra ones attached. Anybody any idea why just the tails should be out? Failing that, can anyone confirm the wiring colour which supplies that particular bulb?
