Technical Tacho on a Punto 55S???????
you don't have a round ignition coil, but 2 coil packs there are on the right of engine follow the plug leads and you will find them. I dont know how to wire angthing to it though.
Please do not Email or PM me asking for support. Post on the forums instead. Your reply may help someone else. Thank you
don't go near the ignition if you're not 100% on what you're doing.
Met Cognac 99 Brava 100 HSX, wish it'd clean itself!
You should have bought an SX :p
Spirito di Punto | M-reg 55SX, black, 5dr. Clear repeaters. Remote locking fitted, no light confirmation yet though - need relay fitted
If you get a Instrument set from a written off 60s with a tacho it fits perfectly. Wires up which means there no use for a external tacho.
i've already got the tacho and mounting and it looks pretty good so i'll stick with it. not got round to fitting it yet but if mad_colm is right then i'll be a happy man. apparently it might be a bit tricky to fit because of the punto's dual coil pack so if anyone has any suggestions i'll be most grateful to you.
if thats the case then u can soon fix that with use of an amplifier chip and setting up the resistors to amp it to double the voltage, i'll have a read through em old electronics books and see how to do it, btw this chip costs meer pennys, so not really expensive job!
Pete
Cruisewilmslow.vispa.com
